Water pump failed. How long before Opti does too?
Old 03-03-2019, 09:57 PM
  #31
Dave1980's Avatar
Re: Water pump failed. How long before Opti does too?
I would go electric water pump. Then keep optical portion of opti and run LTCC.
Or you can go big and buy my 24x setup sitting in my garage....
Dave1980 is offline
Old 03-06-2019, 10:19 PM
  #32
Looking at the availability let alone the cost of a replacement engine harness the 24X conversion makes more sense. And a 24X allows Gen I sbc installation. Heck I don't see why a BBC can't run on 24X ignition and computer. I maybe dreaming here but a BBC in my 4th gen is what I really want. I'm just not a LS fan. If I did want a LS powered car I would start over and buy a late model 4th Gen camaro.
Distributorless ignition conversion seems to be getting better but it's still a huge commitment in effort and money. Heck once you start a 24X conversion you are married to it. I have to wonder how many distributorless ignition conversions have made cars into garage furniture never to run again? I'll struggle on with the opti as I like driving my car more than dreaming about it.
cardo0 is offline
Old 03-31-2019, 09:31 AM
  #33
Only one trouble code was stored: #36 - high resolution failure. Hmmmm, what could that be?
Car still starts and drives so its a matter of finding a location to do this and the time to do the swap also. There goes my vacation time.
Water pump has to come out again so why not upgrade to electric? Well another $200 but its just something I want to do so now is the time. Also found a 4 terminal "delay after break" relay for 'bout 25 bucks. Most W/P's are relayed anyways and this is adjustable for up to 3 min run time after engine off. I'm think'n 1 min of W/P run after shut down would be enough.
So I need a 4 prong relay base to wire my relay into it. Anyone know where to find a automotive cube relay base?
cardo0 is offline
Old 03-31-2019, 10:47 AM
  #34
Super Moderator
Clear the code and see how quickly it comes back.
The engine will run with DTC 36, suffering only a minor loss of timing accuracy on the ignition (increased spark scatter) and injection..... probably never notice it. Can be a harness problem, corrosion in the Opti connector socket, damaged pin on the connector. Or, the problem could be an issue with the optical cam position module in the Opti, dirt/oil/rust particles on the shutter wheel or emitter/receptor, etc.
Injuneer is offline
Old 03-31-2019, 11:22 AM
  #35
I think it's heat related. Because it takes something near 30 minutes to fault and it returns shortly after stopping and restarting. But let the car sit overnight and it will take over 30 minutes again before the fault returns. That's not the behavior of a loose/poor connection.
cardo0 is offline
WS6T3RROR
04-24-2009 10:18 AM
95LT1Z28
09-15-2004 04:57 PM
Jkren
07-16-2004 10:24 PM
TomsBlackZ
12-31-2003 09:22 PM
kevkop94TA
05-04-2003 07:39 PM
Quick Reply: Water pump failed. How long before Opti does too?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
