Water pump bolts leaking again:what type of sealer are you guys using?
#16
Re: Water pump bolts leaking again:what type of sealer are you guys using?
You cannot use Rtv on paper gaskets. When the coolent hits the RTV it will eat away the gasket and you will have leaks. Dont put any thing on paper gaskets. Use blue thread locker on the water pump bolts and make sure the old gasket material is all cleaned up and you should have no leaks.
#17
#19
I must be leading a charmed life or something because I never even thought about putting sealant on the water pump bolt threads and never had a leak in all these years and have had the pump off maybe 4 times total for one thing or another. I did use copper coat on the paper gaskets as I always do. I guess you never stop learning about your car. Maybe I should read my manual once in a while.
#21
Location: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
The white teflon thread sealant has always worked for me, but I'm not sure of the brand, or name, or specific contents. I forgot to put it on the bolts once and it leaked immediately. I can't imagine getting by without some sort of sealant on those bolts. I also put some copper permatex on the gaskets.
10-31-2016 11:09 AM
