water pump
Old Feb 18, 2004 | 01:13 PM
SilverZ24's Avatar
water pump
Anyone ever change a water pump on a '95 Z28? Is it anything like the older style 350/305 engines? Any little things I need to know about? Thanks.
Old Feb 18, 2004 | 01:26 PM
94_formula's Avatar
try not to spill coolant down the motor, other than that its about a 30 minute job or so.
Old Feb 18, 2004 | 01:42 PM
Zachz28's Avatar
30 min. NO way the book even says it takes 2 hours
its is completly different from an old SBC it is cam driven you more like 4 hours 1st time not hard just time consuming
Old Feb 18, 2004 | 01:53 PM
Z28 Redneck's Avatar
My father and I just replaced our 94 Z28's last night, and I admit it was a pain in the @$$. The main problem is that you have to take off just about the whole front of the car to get to it (lol), but of course, he knows more than I do...
Old Feb 18, 2004 | 03:20 PM
WS Sick's Avatar
Drain the antifreeze, remove the fan assembly, remove the hoses and bolts , clean surface, reinstall.... how hard can it be.....lol
Old Feb 18, 2004 | 08:56 PM
SilverZ24's Avatar
Thanks for the replies. Doesn't sound too bad.
Old Feb 18, 2004 | 09:11 PM
fuzzyz28's Avatar
Yeah, it will definately take you a few hours; take your time and do it right. I replaced mine on my 94'Z; wasn't too bad, but took WAY longer than 30 minuntes!
Old Feb 18, 2004 | 09:38 PM
93midnightta's Avatar
it's not hard at all and it really shouldn't take you that long. but then again when your tear the whole front end apart to do the opti the water pump job seems really easy .
Old Feb 18, 2004 | 11:30 PM
RENE95Z's Avatar
I wish it was just a 30 minute job. Took me and a friend around 2-3 hours. Not difficult as stated above, just time consuming. You may want to get different clamps than the OEM clamps when putting everything back together; just in case you get a pump that doesn't hold up well and you have to pull it and put in another one. Guess how I know this.
Old Feb 18, 2004 | 11:51 PM
revtime's Avatar
Water pump is not bad.
I suggest changing out the opti if its suspect..alot easier to do then.
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
