water crossover
Old Oct 16, 2004 | 02:25 PM
WheelsupChad's Avatar
water crossover
do you have to run the cross over on the rear of the heads ......would like to plug them off would it run hot ?has anyone plug them???
Old Oct 16, 2004 | 02:34 PM
n2ceptor's Avatar
Re: water crossover
It will over-heat... Its a steam/air cross-over tube....
Old Oct 16, 2004 | 10:48 PM
Spinner's Avatar
Re: water crossover
Gotta have them to keep air out of the heads. Part of the LT1 cooling system.
Old Oct 16, 2004 | 11:02 PM
ejfagala's Avatar
Re: water crossover
There are holes that are pluged on the front of the heads (At least on my AFR's) if you wanted to move the steam vent to the front but you absolutly need it or you will overheat. BTW why do you want to block it off?
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 27, 2015 01:07 PM
