CamaroZ28.Com Message Board
-   -   Voltage Wire on MAP? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/voltage-wire-map-409807/)
Deenasty Nov 14, 2005 02:01 PM
Hey guys, im gonna be hooking up my lm-1 to monitor rpm, AF, and map. Which wire is the voltage wire off of the MAP sensor? I know I can just test it, but I rather just get the info from you guys. Thanks a lot fellas!
speedmiser Nov 14, 2005 02:15 PM
Re: Voltage Wire on MAP?
It's orange on my DFI, but I believe its green on the stock harness.
Deenasty Nov 14, 2005 02:43 PM
awesome..Thanks! On a side note, how do you like your DFI? What did it set you back?
speedmiser Nov 14, 2005 06:46 PM
I'm running the older Accel Gen 6 DFI - it's ancient in comparison to some of the new systems, but it works just fine for me. I bought it new about 3 years ago - so did a buddy of mine, so we were able to split the cost of the software and cable. I've got about $1100.00 into it. I don't think it's available any longer though...
