vibrating shift knob
Old Oct 9, 2003 | 12:30 PM
Mystic97Z's Avatar
vibrating shift ****
hey guys,
got a 97 six speed z28, just installed jet hot lt's and hooker y-pipe, had both motor mounts off, we were jacking up the engine by the transmission,,,
when i'm on the highway in 6th gear at about 16-2000 rpm's my shift **** shakes alot, also when its in neutral at a stop, it still shake a little bit, and sometimes under acceleration. what could be causing this? a transmisison mount? are they hard to change??
Old Oct 9, 2003 | 12:38 PM
94formulabz's Avatar
Your running on 7 cylinders because you burned a plug wire or cracked a sparkplug
Just think how fast it will be once its running on 8!
Old Oct 9, 2003 | 12:44 PM
Mystic97Z's Avatar
u think thats what it is?? it wouldn't be the tranny mount?
i know when i took the plugs out, one was cracked, but it was still in tact and everything,,,y would that make my stick shake?
Old Oct 9, 2003 | 12:57 PM
I highly doubt you jacked it high enough to screw up your tranny mount, did you loosen it?
Your stick will shake because if your running on 7 cyl your motor just isn't balanced anymore. your only getting 7/8 of your torque delivery.
Where was the one that you took out cracked? did you reuse it? If so, DefinitlY replace that before you do anything else.
95% of people's problems after headers are plug wire issues and the symptoms are just as you described I was very carefull with my wires and didn't burn any like most people do, but i did crack a sparkplug since i put the headers in place without tightening them down, then put in the sparkplugs, then tightened the headers down.
Old Oct 9, 2003 | 03:52 PM
Mystic97Z's Avatar
thanks man, went and got a new plug, put it in,,,good as new
i though for sure it was the tranny mount.
Old Oct 9, 2003 | 04:03 PM
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
autoxr166
Sep 25, 2015 04:21 PM
marlar98
Sep 19, 2015 07:53 AM
themex2002
Sep 2, 2015 03:47 PM
