CamaroZ28.Com Message Board
-   -   Valve Spring Questions (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/valve-spring-questions-390715/)
snod83 Aug 16, 2005 09:11 PM
Alright, here is the cam that I have:
Duration Lift w/ 1.6 rr LSA
218 0.528 0.537 112
I was wondering what spring I should use, I have been thinking about the following options:
Crane cams 10308 kit with 99893 dual springs
Comp cams 983-16 springs with stock retainers/locks
Comp cams 26918 springs with stock retainers/locks
Any opinions are welcomed. I am looking to use as many stock parts as possible, such as the retainers and locks (not sure if possible) and I was also hoping to spend as little cash as possible! (haha, not gonna happen). I do not want to cut the spring pockets....
Thanks for your help,
Ryan
rskrause Aug 16, 2005 09:18 PM
Re: Valve Spring Questions
The cam manufacturer is the best source for this info. Why are you using a single pattern cam in an LTx motor, just curious.
Rich
snod83 Aug 16, 2005 10:53 PM
Sorry I made a mistake,
Duration is 218/224
Lift with 1.6s 0.528/0.537
112 LSA
I appologize, I am a horrible typer!
Thanks.
Ryan
1racerdude Aug 17, 2005 10:27 AM
Whatever springs ya get get retainers and locks too. I didn't and it cost an engine.
Call the cam maker for recommendations on springs.
BUBBA Aug 17, 2005 10:50 AM
10308 kit. JMHO :cool:
SStrokerAce Aug 17, 2005 01:24 PM
26918's are the best choice.
Bret
96capricemgr Aug 17, 2005 02:27 PM
You need to do some more research as those wont work with stock retainers and while stock locks might work I would think a set of +.050s would be better. I agree with Bret that they are the right springs for the job, you just can't use them with the parts you wanted to.
JustNO Aug 17, 2005 02:36 PM
I can't understand.. We can use 26918 for a smallest cam to a big cam.. Its very usable.. What is the end limit specs for 26918??
SStrokerAce Aug 17, 2005 03:22 PM
depends on the RPM and lobe profile. If you get the 26918's get retainers and locks to go with them.
Bret
JustNO Aug 17, 2005 03:36 PM
What is the part number of titanium retainer for 26918? Everyone says different thing..
BUBBA Aug 17, 2005 04:04 PM
Unless you plan on spinning 7 grand, you might want to spend your loot on something other than titanium retainers. JMHO :cool:
96capricemgr Aug 17, 2005 04:21 PM
One of the key benifits of beehives is the smaller and therefore lighter retainer being smaller a switch to titanium will net you a whole lot less weight savings than it would with traditional springs and retainers, by the time they become a remotely good idea I would think a rev kit would be a better way to spend that money.
