CamaroZ28.Com Message Board
-   -   Valve spring question (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/valve-spring-question-499501/)
1997blackz28 Jan 31, 2007 10:07 PM
will this spring with the required retainers: http://www.gmpartsdirect.com/perform...CATID=734.html
work on my 97 LT1 z28? will it fit the stock heads with out any machining or other issues? Will it work with SA roller rockers and hardware from the hotcam kit. Will it work ok with a CC503 cam 224/230 .503/.510 112 LSA?
