Valve Cover
Valve Cover
I'm planning on getting a set of aluminum valve covers, I just ordered a set of 1.6 Crane Gold RR's. My question is will the Crane's have any clearance issues or will should I get the taller ones. Also will my alternator have any clearance issues if I go with the taller valve covers. Thanks Mike
you will most likely have alternator clearance issues if you go with taller valve covers. '
Fortunately for me, mine are "Custom" aka: previous owner took a hammer to the valve covers to clearance them.
you could always go that route. I dont really mind it since the alternator covers the "custom work" anyways
deerslayinrenek:
There is no clearance problem with the Crane 1.6 SA Gold narrow bodies and stock covers. I read that with some (Proform?) tall covers that a small amount of grinding in one spot on the alternator case is all that's necessary. Try a forum search about the brand you want and clearance issues.
Good Luck
Good Luck
carguyshu
Jan 22, 2017 11:19 AM
