Which valve is which
I'm trying to set my roller rockers using Shoebox's method and in order to do that.........Yes a very stupid ? but..........which valve is which?????? intake valve and exaust valve........lol.......thanks in advance for the help......
Thanks for the input Ya'll. I know it sounded like a dumb ? but I wasn't sure.......and Shoebox I assume that that sequence is the same to both sides....and also I noted that you have previously said that it doesn't really matter if the enging is warm or runing because of a spring that is putting pressure on the pushrod. Am I correct. I adjusted them before and they are a little off....dag gum roller rockers..everyone seems to like them but have a little trouble adjusting them.......I'm adjusting them again because they are still making some noise....no clattering just a ticking sound.... So how much noise should they make if any at all?
The heads are symmetrical, so they look the same on both sides.
Roller rockers will click a little more than the stock ones. As far as hot or cold, it does not make any difference as far as pressure within the lifter, but it can make a small difference because of thermal expansion of the metal pieces. That said, in my mind, it can't be that crucial since people use preload ranging from 1/4 turn to 3/4 or more.
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
