Vacuum at WOT
Old Oct 20, 2004 | 09:52 PM
TQdrivenws6's Avatar
Vacuum at WOT
I just got back from the dyno the other day, and while looking through my logs, I am seeing 1" of vacuum from 3krpm-4krpm, and 2" from 4krpm-5.5krpm, and 3" from 5.5krpm-6.8krpm.
I have a TPiS 52mm t/b, WS.6 intake, and a drop in K&N filter.
From all that I have read, 1" or less is desireable, so I am trying to find my bottle neck. My first thought would be the stock bellows, so I will swing by Home Depot to pick up the Fernco coupler that Fred seems to promote, but what would be causing all that restriction? My only other guess is the K&N might not be big enough.
Old Oct 21, 2004 | 12:50 AM
1982z28with18s's Avatar
Re: Vacuum at WOT
My setup in sig pulls ~2.5" at wot above 5500rpms. I think my problem is the stock throttle body though.
Old Oct 21, 2004 | 12:59 AM
Z95m6's Avatar
Re: Vacuum at WOT
i think you need a bigger TB. I believe your engine should start to build vaccum again after you're WOT.
Old Oct 21, 2004 | 01:53 AM
97WS6SCharged's Avatar
Re: Vacuum at WOT
Just put a blower on it. I see 0" at 1/4 throttle.
Seriously though, have you checked to make sure the blades are opening all the way at WOT?
Old Oct 21, 2004 | 06:04 AM
Re: Vacuum at WOT
Blades are opening all the way.
magman
Apr 15, 2016 03:08 AM
PopoFormula
Oct 12, 2015 04:19 PM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
