Vacuum on 383 engine
Old Aug 27, 2007 | 01:43 PM
93BlackTA's Avatar
I have ben doing a little searching and have found some useful information but still a little confused....I have a 383 fully forged bottom end with 8.5:1 CR, AFR 195 Heads, BB custom Cam, and a procharger. I am having some trouble with low vaccum....if i read correctly, if i subtract the Map reading from the Baro reading then that should give me my vacuum reading correct? if so, i am getting 5-8 @ idle.....this seems a little low isn't it....what would i experience if this is the case...My brakes seem fine....
Old Aug 27, 2007 | 02:42 PM
JAKEJR's Avatar
If the reading is ACTUALLY 5-8, then your brakes would be hard as a rock after the first application.
Say, you come to a stop at a traffic light. the the light turns green and you pull off ONLY to have to stop immediately for some reason. You'd have virtually no brakes. Pedal would be brick hard.
I recommend you just buy a vaccum gauge from an auto parts store and connect it to a intake manifold source - I use the power brake fitting - and take a reading. Depending on a few variables, like camshaft duration, the reading should be above 12. The shorter the cam duration, the higher the reading should be.
Also, the reading should hold relatively steady, with no sudden dips.
Jake
Old Aug 27, 2007 | 07:20 PM
OBE1 95Z28's Avatar
I highly recommend you get a boost/vacuum gauge since your running a blower. Great diagnostic tool.
Old Aug 27, 2007 | 07:22 PM
93BlackTA's Avatar
Yes i have one mounted in the pillar pod and noticed it is reading pretty low at idle
Old Aug 27, 2007 | 07:35 PM
BlackDog's Avatar
Try increasing the timing at idle. Maybe somewhere around 32-36*.
Old Aug 27, 2007 | 07:40 PM
93BlackTA's Avatar
right now i'm seeing 23-30 degrees at idle using datamaster...would it indicate a vacuum leak if im reading that low? How about if the duration was in the 24x-25x range? what symptoms would i get from a vacuum leak?
Old Aug 27, 2007 | 07:43 PM
WS6T3RROR's Avatar
if your durations are that high probably your only chance for better vacuum is going to be to crank the idle rpms up.
Old Aug 27, 2007 | 07:47 PM
93BlackTA's Avatar
Its idling @ 1000, I am very close to cancelling this project.....I am not impressed with it at all..
Old Aug 27, 2007 | 07:58 PM
BlackDog's Avatar
Just try adding the timing. It helped with my cam. What do ya got to loose.
Old Aug 27, 2007 | 08:03 PM
93BlackTA's Avatar
its a 93 so i have to get chips burned...its a pain, I sent a datalog to Alvin and when they get settled away in the new shop hes gonna have a lookat it....hopefully he can figure out something...its mostly just numbers to me...lol
Old Aug 27, 2007 | 09:43 PM
WS6T3RROR's Avatar
i dont know crap about 93 model stuff... but isnt there a way to modify your ecm so you can run an emulator of your chip and try changes without burning a new prom?
Old Aug 27, 2007 | 10:24 PM
joe-96z1le's Avatar
My stroker with a custom cam (22x,23x) and a blower idles at ~900 rpms with 12" vacuum. Your cam is much larger. I'd contact the custom cam designer and ask him what the vacuum should be at idle. My BRE cam is right at where I was told it would be. I also think your idle may be a bit low. Is the car an auto and is the car idle in park or drive?
Old Aug 28, 2007 | 05:06 AM
93BlackTA's Avatar
Mine is M6. The idle is set at 875 but it will not idle that low.... I have contacted Bret and just waiting on a reply now.
Old Aug 28, 2007 | 03:08 PM
CamaroZ2869C's Avatar
i have a 242/248 and im having vaccum problems on a 12:1 383
Old Aug 28, 2007 | 03:23 PM
dangalla's Avatar
what problems are you having with low vacuum? any, because you did not post any and you said your brakes are working fine? or are you just upset cause your calculations came up with a low number
stop crunching numbers its a waste, buy a real vacuum gauge their cheap, and figure it out from there
