vacum line undr the TB what does it do? i broke it
like i said i brok mine tried to fix it with a lil tape, doesnt seem to be working what does it do?
Re: vacum line undr the TB what does it do? i broke it
Originally posted by 97formula1234 like i said i brok mine tried to fix it with a lil tape, doesnt seem to be working what does it do? |
no not the one going to the PCV it is under that. it started at this lil box looking thing on the passenger side (the vacum pump i guess) and goes under the TB and over the drivers side valve cover below where the PCV one is.
I guess i just have to fix it... |
It goes to the EGR,
You can plug it if you've blocked off the EGR. |
Sounds like an EVAP line to me.
yeah thats the one shoebox the that goes under th TB and makes a "u turn beside the valve cover"
What does that do and should i replace it |
i broke mine too. i just used a rubber vaccuum line end and cut it so i could connect the two broken pieces. plugged it back in and no probs yet.
Originally posted by sabre81 i broke mine too. i just used a rubber vaccuum line end and cut it so i could connect the two broken pieces. plugged it back in and no probs yet. The EVAP system pulls vapors from the gas tank, then burns them with the air and fuel during combustion. If you leave it broken you will likely smell gas fumes and also have a small vacuum leak any time the solenoid is energized. I'll dig up a part number for the plastic hose and edit the diagram to include it. |
