Using teflon tape on spark plug???
Old May 8, 2003 | 04:55 PM
Crazy8's Avatar
Could i use teflon tape on a spark plug. it doesnt seem to go all the way in the hole and it is leaking alittle. Would using teflon tape work. Thanks.
Old May 8, 2003 | 04:57 PM
craigffb's Avatar
You need to use anti seize on the plugs.
Old May 8, 2003 | 05:04 PM
Crazy8's Avatar
do i need to use anti-sieze with the teflon tape or just anti-sieze??
Old May 8, 2003 | 05:07 PM
joeSS97's Avatar
Try running a tap in it.Why wont it go in?
Old May 8, 2003 | 05:15 PM
Crazy8's Avatar
i dont know why it wont go in, i think it might be crossed threaded. i was told that i could try to use a thread chaser, but i dont want to mess anything up....
Old May 8, 2003 | 05:27 PM
anaik's Avatar
Did you check where the spark plug seats in the head for crud or something preventing it from seating.
Old May 8, 2003 | 05:30 PM
Dave19yz28's Avatar
not to be a jerk...but it sounds like something is already wrong...
see if maybe one of the other plugs will fit in the hole, if thats the case...get a new plug...if not, doesnt look like you've got much of a choice.
Old May 8, 2003 | 05:43 PM
Chuck2's Avatar
If you do decide to run a tap down the threads you should buy a tap that is made to use on a head. NAPA now has them available with a cup type magnet on the end so that no metal shavings fall into the cylinder wall. Just a thought
Old May 8, 2003 | 07:00 PM
Mtrhds94Z's Avatar
Magnets not going to do much on aluminum heads!
Teflon tape would 'insulate' the ground too...
Anti seize is whats used on plugs..
jayblev95
Jun 7, 2015 04:04 PM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
