CamaroZ28.Com Message Board
-   -   unvented opti conversion to vented how??? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/unvented-opti-conversion-vented-how-115895/)
FBodyzSS May 4, 2003 09:25 AM
Hi i have a 93 camaro and it needs an opti i want to change it to the newer 95+ style that is vented what will i need to get and where to get it all? And do i have to fabricate anything or is it all plug and bolt on?
thanks
Fastbird93 May 4, 2003 09:57 AM
As for the opti, you need a vented opti, vaccuum harness, wiring harness, timing cover, and the dowl on the cam either has to be lengthened or shortened, I can't remember right off hand. Nu-Tek sells a complete kit with a cloyes timing chain and mezier water pump for something like $750.
On another note, noticing that you're new, check this board out:
Speed Density LT1 Tech Forum
Good group of guys and know what they're talking about. Have fun!
SWINGRRR May 4, 2003 09:58 AM
It is pretty much bolt on since you use stock parts. I did the LT4 cam swap when i did mine. I have a 93 also. I got everything form Jason Cromer for about $900. Just give him a call, he know ever part number off the top of his head. Jason Cromer If you hit any hard spots, just ask. It's pretty easy.
Injuneer May 4, 2003 12:05 PM
Check THIS LINK for parts list and how-to.
