Unexplained knock retard.
Old Nov 11, 2005 | 01:15 AM
Cerwin Vega Fan's Avatar
Question Unexplained knock retard.
I have done two WOT runs where the scanmaster has recorded a knock retard of 10 and 12 degrees. Other times whenever I take off from a stop the scanmaster starts to read a knock retard under very light throttle conditions and it goes up as I give the car more throttle (0.1 to about 1.8 degrees of retard). The odd thing is that some days the scanmaster will record 0 knock retard even under WOT. At first I thought it may be because the engine might be running to cold (160 T-Stat) but I know for a fact when the scanmaster recorded the 10 degrees of retard at WOT my LT1 was at operating temps. Any input on the subject would be appreciated.
Old Nov 11, 2005 | 03:54 AM
SS RRR's Avatar
Re: Unexplained knock retard.
The first step I would take is to run a few tanks of gas from different stations to see if it changes any. When is the last time the plugs were changed?
How about mods? If so, what are they? Any custom tuning done?
When you go WOT what RPM are you at? What gear?
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
