| Andrew04ME |
May 13, 2004 07:52 PM |
Unending Overheating Problem
Cars runs hot in the city. The past couple weeks i have just left the defroster on, high heat, lowest speed. The temp gauge never went above 180-190 approximately. Yesterday, i changed the thermostat, drove it around in 85-90 degree heat, with heat off, wouldnt overheat or get close to 3/4 temp. However, i didnt tighten the two bolts down enough, and it had a small leak. So today i unbolted it, lined the t-stat up with the gasket, no leaks. When i drove it around today, i could literally watch the temp gauge rise. I had to park it on two seperate occasions to let it cool down. And of course it would gush coolant out the reservoir while it was parked. I got it home and realized i didnt bleed the two little screws. Did that and it hissed for quite a while. After all of this,when i tried to turn the fan on, it would blow COLD air on the HOTTEST setting on defrost. Let me recap : defrost, temp nob in the red = feels like air conditioning. I was happy yesterday, i just figured i needed to tighten it down and it would be just fine. WTF?
Nobel prize to whoever helps me get this right...
