Two questions...
Tomorrow I am going to be replacing the waterpump and might as well replace the opti because it is soaked too. I think I can get all dealer items at cost through my work.(any idea on what cost may be??) My first question is do I need to use any gasket sealer? I have the two gaskets for the water-pump but wasn't sure if I needed any permatex or anything? My second question is do our cars actually have PCV valves? I cannot find mine for the life of me and it is really embarrassing.
PS: Are there any other things I may need to replace the opti and the water-pump? Thanks in advance! :bow: |
Re: Two questions...
25th T/A equals '94, right?
If so, I believe it - PCV - is like the 93 - on the driver's side of the manifold. It's in the middle there, and just does a quick u-turn and goes right back in the manifold. According to Haynes - apply RTV sealant to both sides of new gaskets. |
If so, I believe it - PCV - is like the 93 - on the driver's side of the manifold. It's in the middle there, and just does a quick u-turn and goes right back in the manifold. According to Haynes - apply RTV sealant to both sides of new gaskets. I used RTV on both those gaskets. If you're changing the opti, it might be a good time to replace the seals in the timing cover if they show signs of leaking. A new non-vented opti should be ~300 or so, maybe more. |
| All times are GMT -5. The time now is 10:31 AM. |
