Turn Signals Inop
Turn Signals Inop. 4 way flashers work so I assume fuse is good. Any ideas?
Re: Turn Signals Inop
Separate flashers for turns and 4-ways. Separate fuses.
http://shbox.com/1/flashers.jpg 1995 4th Gen F-Body Exterior Lights |
2 separate flashers thanks for that. Fuse was blown after 30 years. Good to go for now thanks.
Replaced flasher. No help. Operated turn Signals while inspecting and shaking down wiring and fuse didn't blow. As soon as I started engine fuse blew. Still troubleshooting.
I can’t seem to access the Shoebox schematic I linked above. As I recall, the schematic showing the fuses indicates there are one or more additional loads on turn signal fuse, as indicated by an arrow pointing off to the left, with a reference to the next drawing page number. You need to look to see what other loads are on that fuse.
Thanks that might be helpful!
Do you have the 1995 factory service manual?
Free download: https://www.mediafire.com/?40mfgeoe4ctti |
More info. Back up lamps are also on same circuit. Fuse blows when shifting to reverse. Next move isolating switch on trans. Progress
Ok just to bring this thread to the fix. I replaced the Reverse Light Switch (Was the Fuse blower) on the Transmission. Turn Signals and Reverse Lights ops ck good now. Installed some LED Reverse Lights too just because.
| All times are GMT -5. The time now is 12:00 AM. |
