Turn Signal problem
Ok, turn signal has been acting weird all of a sudden.
1) Left blinker works fine, but right blinker doesnt light up on the dash but it still clicks. 2) I can hear it click but it sounds different. Definately not like how it use to click. Also, when when I turn my headlights on and I signal my right turn signal, my dash display lights up the signal but doesnt click. The light doesnt even flash. 3) I noticed that when I have my interior dim lights turned on high (interior lights not on tho) when I hit the brake...my stereo light dims low..?? mmm k? Ok, so whats happening..I did change some bulbs in my tailights the other day and I was wondering if that was the reason for this happening. I have no idea how sensitive the electrical is on these cars? I never heard of this ever happening by messing with some bulbs. Whats weird is that this has happened before and then all of a sudden it went away. So if anyone has some feedback on what the prob is, that would be a help bcuz this turn signal is pissing me off. Thanks ? Bad signal switch ? |
check blinkers for burnt out bulbs
I had the same issue with my car and after replacing bulbs, and flashers. My problem turned out to be a bad ground to the turn signal socket.
| All times are GMT -5. The time now is 06:23 AM. |
