Turn signal
Turn signal
Hi,this is on my uncles behalf he has a 95 firebird convertable and one of his flashers/blinkers went out, i went to autozone and they gave me a fuse and when i looked under the drivers side dash i foung a siren, hazzard and horn fuses there, i cant find the blinker one, if anyone has any clue where it is it would be much appriectiatd, also for some strange reason when i was messing down there the seatbelt light went on. any ideas??? thanks in advance
Turn signal flasher
If only one side is not flashing, there is probably a bulb with an element burned out.
Seat belt or maybe air bag light went on? If air bag, make sure the yellow wire and connector are plugged in well. I would remove the air bag fuse before messing with it, though. Put the fuse back in, when you are done.
stangspank
Nov 13, 2015 01:02 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
