CamaroZ28.Com Message Board
-   -   Tuning software (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/tuning-software-473025/)
Camaro350z28 Sep 16, 2006 11:40 PM
Tuning software
I have a laptop and am wanting to get into tuning and some data logging. I have a 94 lt1 vette and a 97 lt1 z28. Do i need 2 cables and different software for each car and what would you suggest and where can i get it? Thanks
oops was in wrong forum when i posted but maybe this will slide or get moved....
Dave '97 Z28 M6 Sep 16, 2006 11:51 PM
Re: Tuning software
The '97 Z28 is OBDII, and (AFAIK) the '94 Vette is OBDI. That means that you'll need 2 different cables and 2 different programs.
I would suggest converting the Z28 to OBDI... then you would only need one program. The OBDII tuning software is significantly more expensive.
Cables: http://www.akmcables.com/ or http://www.moates.net/
Datalogging Software: http://www.ttspowersystems.com/
Tuning Software: http://www.tunercat.com/
(both pieces of software also available at AKM)
