CamaroZ28.Com Message Board
-   -   Tuning Program questions (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/tuning-program-questions-110588/)
hairbear21 Apr 22, 2003 11:57 AM
I have a question reagrding tuning programs. I have looked extensively into LT1 Edit and Tunercat, and they seem relatively the same, but the price is a lot different. So, what I was wondering is what kind of gains can I see with LT1 Edit, and what kind of gains can I see with TunerCat. The only mods are listed in Sig, and for now, I want to change fan temps, etc... But I will be adding a cat back and some other things, and I was curious to know what I would see as the car sits now. Otherwise, I will start looking into other mods until this will be more beneficial.
Thanks for the replies!:D
carnutz Apr 22, 2003 12:13 PM
I have a simular set up, mostly stock, bought tunercat. I look at it this way, I have a stock car but plan on a cam, heads, stroker and maybe a blower in the future. I wanted to do a couple of things, I fell into realy cheap gears($25 3.73's new) so I need to change the speedo, I wanted to do fan temps and program out the cags. I looked at a power programmer (about $400), custom tunningat that or more for each time I add something, or tunnercat at $90, a cable for $65. I picked up a used laptop from a computer store,(PII,300, etc.) for $275. So I have 430 in a device that does way more than a powerprogrammer, is way cheaper in the long run than custom tunning, and way handier (no down time sending out the PCM). I dont understand all of tunercat but am learning, I also downloaded Freescan and never will I take to a shop to get the codes read or cleared. so for $430 I figgure I am ahead by far in the long run......I am happy I went this way even tho' I am not using tunercat to it's full potential YET. Your gains with that set up would be minimal but if you plan on more indepth mods............ You decide....
Bastardcat Apr 22, 2003 12:32 PM
I think you hit the nail on the head.
hairbear21 Apr 22, 2003 12:34 PM
Thanks for the info, that really helps. What are some of the things that Tunercat can do? I know that you can change speedo settings and fan temps, but what are some of the "power" tunning options that are available? I have heard that people can see anywhere from 10-20 horsepower just by using this tuning. I know that 20 horse is REALLY pushing it, but even 10 would be good for me, because all I need is the software and an interface cable. And for the cash, to even see 10 horse for 150 bucks isn't that bad.
MyTMous Apr 22, 2003 12:37 PM
I found that with Tuner Cats and TSS Datamaster I can do anything I want.
That and I can use my tuner cat on my buddies cars, where LT1_Edit is locked to one vin unless you have $1500 to spend.
Once you get into Cats you will find there are more things you can do than you can learn about. But I am trying my best to find it all out.
Give me another few months and I will have my website with the cat Tutorial on it with files and everything.
Our #3 kid is due any day so I have other thing to work on right now.
mastrdrver Apr 22, 2003 12:51 PM
Does Tuner CAt work on OBD2 cars?
turbo_Z Apr 22, 2003 03:41 PM
nope. only LT1 edit for OBD2 cars. youll be forced to pay $500ish for the LT1 edit unless you convert to OBD1.
