CamaroZ28.Com Message Board
-   -   tune for higher octane? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/tune-higher-octane-474690/)
frankthetank078 Sep 24, 2006 09:27 PM
if you get you car tuned for higher octane (93) do u pick up any HP from it?
knta4dnu Sep 24, 2006 10:31 PM
Re: tune for higher octane?
The fuel itself doesn't give any more power. It helps prevent pre ignition, which the knock sensor will detect and then retard the timing, which will then cause you to LOSE power. If you're having the car tuned, and the tuner knows you will always use the higher octane, he can be more aggressive with the timing, which will give you more power.
Bow94z Sep 24, 2006 11:39 PM
www.madz28.com
www.pcmforless.com
good Tuners who will tune for 93 Octane to net you some more Ponies to the wheels:)
2000GTP Sep 25, 2006 08:22 AM
Yes, as mentioned, the tuner will advance the timing a few degrees which will bump your power. Technically, you are supposed to run premium anyways so why not have the car tuned to take full advantage of it.
camaro1fastz28 Sep 25, 2006 10:21 AM
i tuned mine on 110 and it just dont want to stop pulling
