tune for higher octane?
Old Sep 24, 2006 | 09:27 PM
frankthetank078's Avatar
if you get you car tuned for higher octane (93) do u pick up any HP from it?
Old Sep 24, 2006 | 10:31 PM
knta4dnu's Avatar
Re: tune for higher octane?
The fuel itself doesn't give any more power. It helps prevent pre ignition, which the knock sensor will detect and then retard the timing, which will then cause you to LOSE power. If you're having the car tuned, and the tuner knows you will always use the higher octane, he can be more aggressive with the timing, which will give you more power.
Old Sep 24, 2006 | 11:39 PM
Bow94z's Avatar
www.madz28.com
www.pcmforless.com
good Tuners who will tune for 93 Octane to net you some more Ponies to the wheels
Old Sep 25, 2006 | 08:22 AM
2000GTP's Avatar
Yes, as mentioned, the tuner will advance the timing a few degrees which will bump your power. Technically, you are supposed to run premium anyways so why not have the car tuned to take full advantage of it.
Old Sep 25, 2006 | 10:21 AM
camaro1fastz28's Avatar
i tuned mine on 110 and it just dont want to stop pulling
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
Jul 17, 2015 02:47 PM
