CamaroZ28.Com Message Board
-   -   trouble codes (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/trouble-codes-344478/)
badasschevy625 Feb 24, 2005 10:16 PM
trouble codes
hey whats a cheap way to pull trouble codes out of an obd2 car i know scanmaster wont work is there any resonably priced computer that can do this?
indieaz Feb 24, 2005 10:43 PM
Re: trouble codes
Autozone = free.
EDIT: http://www.autoenginuity.com/downloads.shtml <--- their scan tool can be downlaoded "free" - if you have an OBD-2 cable that connects to a serial port allready then you could use it. Also i understand converting an OBD-1 cable to OBD-2 is a simple process (a search in the forum should reveal the answer).
Injuneer Feb 24, 2005 11:02 PM
Re: trouble codes
Harbor Freight sells a plug-in OBD-II code (only) reader for $40. Brent Franker tried it and said it worked fine.
http://www.harborfreight.com/cpi/cta...emnumber=46030
