Trans Am sound system FYI...
Guys some may remember my thread the other day about the speakers in my car turns out it is an amplified factory six speaker system but it's not the bose, so there were some six speaker options on the 95's....Just figured I'd pass the info along.
The Firebird/Formula/TA never got the Bose system. That was only offered in the Camaro. The upgrade to the stock system in the Firbird is a 10-speaker system, that eventually became known as the "Monsoon".... maybe in 96 or 97. There are two speakers in each front door, two speakers under each oval panel in the hatch area, and a sub on each side of the rear seat. There is a sub amp somewhere in the back.
As far as I know that was the only option. |
Originally posted by Injuneer There is a sub amp somewhere in the back. |
I was going to look for it, because its getting removed, along with the rest of the sound system..... major weight reduction :). A buddy of mine has a 97 TA, and he was showing me a box under the plastic cover over the passenger side rear wheel well. But I know my 94 is not located there.... apparently its where you indicated.....
Monsoon first offered in 97, it's a 500 watt system or so they claim. Speakers are not replacabe with other than GM OEM according to my local Sound Shop source.
Originally posted by Injuneer I was going to look for it, because its getting removed, along with the rest of the sound system..... major weight reduction :). A buddy of mine has a 97 TA, and he was showing me a box under the plastic cover over the passenger side rear wheel well. But I know my 94 is not located there.... apparently its where you indicated..... |
I was pretty impressed with the fact it had an amplified system in it already. I replaced the front door speakers with some fosgate fanatics, and put some kenwoods in where the 6.5's went behind the driver and passenger, but those kenwoods are coming out and the factories are going back in.
