CamaroZ28.Com Message Board
-   -   Tranny Mount? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/tranny-mount-888263/)
SSchick1997 May 12, 2020 08:41 PM
Tranny Mount?
When I rip into it my gear shift lifts by about 5 inches. It is a standard and have been told possible cracked tranny mount. Anyone experienced this? I have a 1997 SS.
shoebox May 12, 2020 09:47 PM
Re: Tranny Mount?
Super common for a manual. A poly mount will give better service, but will not isolate vibration as much as a normal rubber mount. In the past there was a mount for the 1LE equipped cars that was a more durable rubber unit, but the separate part number was done away with.
GaryDoug May 13, 2020 12:28 AM
Re: Tranny Mount?
Maybe just buy the regular mount more often?
Chimera96 May 13, 2020 09:38 AM
Re: Tranny Mount?
just replace the trans mount...and look at the motor mounts also....they also may be done
I use the Black energy suspension ones for MM and a stock rubber trans mount
