Tranny leak, NEED HELP.
I have a tranny leak at the end of the transmission, the end seal is dry. It leaks at the u-joint. Anyone know what's wrong and how to fix it.
Is it an auto or manual
The speed sensor is sealed by a large o ring, mine used to leak. Its held in by one bolt, easy fix. It wouldn't hit the u joint directly, but as your moving it would fly straight back to the u joint. |
Its a manual, and its not the speed sensor. Could it leak through the driveshaft slip yoke?
