track results of LE heads-xe 224/230
this was my 1st trip to the track. the density altitude was 3500, and the track prep was non existant. i felt like i was trying to pull out in the rain!!!! it was so slick i couldnt give me more than 1/4 throttle in first gear without bad wheel spin, i couldnt FLOOR it until around 50mph in 2nd. but once the car hooked it had great top end. i was running michelin street tires (25psi). here is my best time slip:
60' 2.54
330' 6.48
1/8 9.45 mph-82.95
1000' 12.0
1/4 14.13 mph 106.27
keep in mind that a bone stock 02 z28 a4 ran consistant 14.1 at 100MPH.
(note to self- next mod ET streets)
what do you all think????
Jesse
60' 2.54
330' 6.48
1/8 9.45 mph-82.95
1000' 12.0
Jesse
Dude those times suck! Sorry to be so blunt, but you shouldve been running those times without the heads and cam.
My buddy has a full bolt on LT1 with the xe 224/230 cam and stock heads and he runs 89 mph in the 1/8!
Those times aren't too hot. You should have been trapping 106 before the heads/cam. I understand the track prep sucked and you weren't able to launch the car hard, so there is a lot left in it. You may see 107-108 mph and high 12s - low 13s with ET Streets. 3000' DA is nothing really. I ran the times in my sig in ~ 4000' DA with stock heads and stock tuning.
Get some tires and see what she'll do. Good luck w/it!
I don't think you can make a judgement at that track. You said the track prep sucked, and w/ a 2.5 60' I believe you. You ran a 14.1...but, at 106, which should give you a very low 13. I'd say with some traction (yes better tires, but good track prep. is important too), you should be in the 12's.
Just my humble opinion,
Dave
Dave
not to mention i have removed backseats, front sway bar, carpet padding, both cats, heat shields for the exhaust, front bumper support, the x brace behind the tranny. but i added KB sfc, and driveshaft loop.
im going to get the car weighed. im thinkin its around 3650 without me (140lbs)
im going to get a scanmaster, do a compression check, and see what i can come up with. its disappointing to spend $$$$ and run slower than most guys with small cam and bolt ons
but theres room for lots of improvement....
maybe a n20 kit would help me feel better
Jesse
Jesse
106mph before heads and cam?? He has an A4 convertible!!
Your times reflect upon your putrid 60'. Go to a track that preps and put some slicks on there and you shouldn't have a problem running mid-low 12's with a good(1.6-1.7) 60'.
im still in shock that i spun so bad, my first run i launched a little harder than i do on the street, 1st gear spun so hard that smoke was boiling off the tires (my wife videotaped me
) it shifted into second spun harder started going sideways, i let off the gas got it under control, looked at my speedo 40mph, floored it and got really bad wheel spin until around 60, then it hooked and started pulling really hard.
i thought i should have gained more than 23mph in the last half of the track? what do you all think?
Jesse
) it shifted into second spun harder started going sideways, i let off the gas got it under control, looked at my speedo 40mph, floored it and got really bad wheel spin until around 60, then it hooked and started pulling really hard. i thought i should have gained more than 23mph in the last half of the track? what do you all think?
Jesse
