CamaroZ28.Com Message Board
-   -   TPS Sensor (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/tps-sensor-302365/)
Joes96z Sep 19, 2004 04:13 PM
TPS Sensor
Does anyone know the color of the throttle position sensor wire that has the voltage. I am almost dont doing my zex kit and I need to know which wire to tap into. There are 3 wires black blue and white .
help me quick if you can thanks Joe
shoebox Sep 19, 2004 04:51 PM
Re: TPS Sensor
There will be two wires with voltage. You need to specify which one you need. Reference voltage or signal voltage. One of the wires is gray, not white. wiring
