TPS Issue..
Well tested my TPS with my DVM and it showed about a 1.70 when close then when the throttle was open it was high 5.XX closer to 6. I tested these number directly off the prongs in the sensor itself.
Is there a way to adjust the TPS or do they have to be replaced? Mike |
If you have those readings, you should also have an SES light and DTC 21. Do you?
Hard to see how a sensor that's supplied with a 5.0V reference signal could be reading 6V. Take the connector off and read the voltage between the black and gray wires. If it exceeds 5.0V, you have a problem with the PCM, or there voltage leaking into the harness wire at some point. |
Well it doesn't actually hit 6 it is just in the higher 5's. I don't know exactly how it's possible but it does lol. These are reading I get directly at the sensor. I did not probe the wires themselves.
Yes I am throwing an SES light. Not sure what the code is as I don't have a reader yet but it does have the light. I also have an idle problem that is high sometimes, other times normal etc... Mike |
| All times are GMT -5. The time now is 08:42 AM. |
