CamaroZ28.Com Message Board
-   -   Torque specs for header bolts? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/torque-specs-header-bolts-443250/)
Texas_96_Z Apr 7, 2006 09:52 AM
Does anyone know of a good site that has information on header bolt torque specs? Thanks for replies
BlackScreaminMachine Apr 7, 2006 10:36 AM
Re: Torque specs for header bolts?
Torque spec = Tight!
Also use a multi layer dead soft aluminum gasket (percy, flowtech), clean both surfaces of the cyl head and header flange for proper seal.
Unless the motor is out of the car its REALLY hard to get a torque wrench in the car. just start from inside bolts and work your way out
scottslt1z28 Apr 7, 2006 11:12 AM
35 ft lbs i believe
