Tornado performance
Tornado performance
Guys i was watching tv and i saw this product called the tornadao. It says it saves like 21% gas milage and has an increase of power up to 20 hp. Iwas just wondering if this is bogus cuz i saw it on tv and my gut says it is. But wut it does you put itin you intake air tube and it has blades that makes the air swirl and i guess so u can fit more air in? But i was just wondering what you guys thought. And if any one has ever tried it? Thanx
This was posted not long ago by Mindgame...
A good friend of mine who use to work with Dale Eicke (famous pro stock head porter) did a test on the Tornado about a year ago. A group of guys in our dragster club got together and decided to chip in and buy one just to see what the hell it'd do. So we all pitched in a few bucks and ordered the thing... having it shipped to my buddies shop. Here's the e-mail I recieved on the tests.....
just did a very quick initial test of Tornado on
SuperFlow SF-600 flowbench
test was just on flowfixture mounted ontop of
digital Swirl-Tester ...no carb or air cleaner , test was
just to see effects of Tornado only
Results = immediately "ClockWise Swirl" was achieved
gradually raised test pressure in inches of water to
2.000" H2O where clockwise swirl maxed out my swirl meter's capacity at 16 to 18 inch/ounces of torque coming in at 2.00
thats 2.000" inches of water , swirl will be tremendous at
2.000" inches of Mercury Hg., beyond my test capabities
to measure any further increases in swirl -torque past
18 inch/ounces
quick initial flow restrictions with ONLY Tornado were NONE
no flow losses , CFM readings remained unchanged
next will begin flow testing with carb, air cleaner, intake manifold, head as total induction system
results to follow later tonight
_______________________________________
just finished more "Tornado" FlowBench tests
flowed Tornado on QJet and Holley 750 double-pumper
attached to Edelbrock Victor "E" SBC intake
on a GM #041x Super Stock max-ported head
Results=
absolutely "NO" difference measureable with
Tornado or without Tornado , when entire
induction system path was flow tested !
The overwhelming cylinder head's intake port
bias influenced Swirl-torque and orientation
(Clockwise or CounterClockwise)
...with or without Tornado in place made no
differences in swirl-torque or flow CFM
Next, removed cyl. head, intake manifold from
flowbench....then flowtested the carburetor
by itself to see if Tornado would create
measureable swirl
Results=
at most the Tornado created Clockwise swirl
approx. bouncing between ZERO and .20 inch/ounces
of swirl torque,..when measured flowing thru carb
I was pretty amazed when i 1st flowtested the
Tornado by itself on just the flowfixture
the amount of swirl torque was amazing !!!
it maxed-out my Swirl-Meter at only 2.000 inches of
H2O test pressure !
However when the entire induction system path was
flowtested with the Tornado as a "UNIT"
the extreme swirl-effect of the Tornado vanished,
completely unmeasurable on my flowbench !!
I increased flow test pressure to as much as
36.0 inches water..still no increase in any measureable
swirl induced by the TORNADO ...very disappointing !
i then had the idea to flowtest the Tornado just
on the carb by itself....i thought surely i would
see very large swirl readings with the Tornado .
Again, very disappointing, the swirl increases
were barely measureable , bouncing between
0.000 inch/ounces -to- 0.20 inch/ounces of swirl-torque
even if test pressure was increased all the way to
6.000 inches of water !
the carb bores, venturis, throttle-plates/butterflys
overwhelmingly canceled out Tornado's swirl !
even with carb butterfly all the way opened,
no changes in Tornado swirl effects.
if the carb itself is just about totally
"negating" the Tornado's swirl effects,
i can easily see why when the entire induction
path was tested , no recordable Tornado swirl effects
were seen .
Very disappointing 1st flow tests .
Will still try out Tornado on 3 dyno test engines
this coming weekend and 1/4 mile drag tests
and mileage test to follow in next weeks .
Will post results as they happen .
PS- about the only good thing i can say so far
is the Tornado did not cause a flow restriction
in all my tests . Flow CFM remained unchanged.
_________________________________________________
18 inch/ounces
Results=
measureable swirl
Results=
H2O test pressure !
were seen .
Aug 24, 2015 06:41 AM
RX Speed Works
Jul 24, 2015 02:25 PM
Catmaigne
Jul 14, 2015 05:17 PM
