CamaroZ28.Com Message Board
-   -   Top Speed Limiter (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/top-speed-limiter-67865/)
Wildwill532 Jan 11, 2003 11:52 AM
Top Speed Limiter
Whats the top speed limiter on a 97Z Automatic
Xride Jan 11, 2003 12:08 PM
I always thought the Z wasnt electronically limmited so its gear limited (from what i have seen) to around 155 mph.
Mtrhds94Z Jan 11, 2003 12:14 PM
Fuel is cut off at 108[some say 115]mph...
[not sure what he means in above post?]
tbehling Jan 11, 2003 12:18 PM
i really dont think the fuel is cut off at 108, my 94 has seen speeds of 150
eyeoutthere Jan 11, 2003 12:20 PM
It depends on the car. If you have a 150mph speedometer, the car is not electronically limited. If you have a 110mph speedometer, it is limited to ~110 mph.
KeVMaN Jan 11, 2003 12:26 PM
I've gone to about 125...
Mtrhds94Z Jan 11, 2003 01:12 PM
If the car came with Z rated [for speed] tires there is no 'speed limiter' at 108...
If it didn't the fuel is cut off at about that speed[ can be 'programmed out']
Gears really have nothing to do with top speed... [ it's all about HP...]
Wildwill532 Jan 11, 2003 01:16 PM
the fastest ive touched was about 145 more like 142 but still, plenty fast! What gears would I have if im at 2k at 60mph
dlx3200 Jan 11, 2003 01:31 PM
If your car is like my 97 Z, it might have 273's.I was told if you have 2 D OD on the shifter section you have 273's. If you have 1 2 D OD you have 323's. I know when I changed my gears it had 273's in it. hope this helps.
95loveaffair Jan 11, 2003 01:44 PM
Exactly. Most will make it to 160ish before they just don't have enough oomph to go any higher in stock form.
Z28Nut Jan 11, 2003 06:09 PM
Where can I order more oomph? I thought I was gonna need heads, cam, blower, nitrous, etc.:) ;) :)
Oh, yeah, that is OOMPH!
My 94Z had a 106-108mph limiter but the Hypertech power programmer III took care of that though I think the PC based tuning software is a better value.
Wildwill532 Jan 21, 2003 07:53 PM
My automatic shift go's 1 2 d OD N R and when im at 60 im at 2k so i have 3.23?
Buttercup Jan 21, 2003 08:38 PM
Yes, you're car should have come from the factory with 3.23 gears. You can't rely on your tachometer for accuracy, most stock tach's read a couple hundred RPM high.
RedWolf Jan 22, 2003 07:37 AM
Go to this web site to find about your 4th generation.
http://www.tcnet.net/~dstorer/jf/
just click on your year.
rsconv92 Jan 22, 2003 07:58 AM
speed limit
i would liketo know how to get mine where it doesnt shut down at 110 becuse i hate these little rice burners passing me after i shut down how can i get rid of that the cheapest way :cry: i want it gone so bad
