CamaroZ28.Com Message Board
-   -   timmimg key help (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/timmimg-key-help-546798/)
93camarochrisz28 Oct 6, 2007 08:56 PM
timmimg key help
ok the timming key i have for my timming gear is a full key not the half key .should i just cut my key or go to chevy and get one from them
shoebox Oct 6, 2007 11:55 PM
It's your call. You could stick the key in, install the gear, mark the key, then pull it all back out to cut it or just buy a key.
93camarochrisz28 Oct 7, 2007 02:25 PM
i did not know if cutting it would make it softer and brake one day so if cutting it is ok then that is what i will do thanks
