timing set
Hello guys I'm doing a cam swap in my z28 just bought a cloyes
C3039 anyone used this set before it's for my 96 z28 says it's for Lt1 But can't find no info thanks in advance |
Re: timing set
Looks like the correct set, with the gear on the back of the cam sprocket for the water pump drive. And the hole in the center is the larger hole, required for the pilot shaft on the vented Opti (95-97).
https://static.summitracing.com/glob...o-c-3039_w.jpg |
| All times are GMT -5. The time now is 01:42 AM. |
