Timing Set
Where can I find a Pro gear single roller set? I can't find it on any of the big names or sponsers..... :(
http://www.progearweb.com/distributo...ibutor_map.htm
Not sure what your setup is, but most, including myself, just went with the LT4 heavy duty timing set... |
I cannot afford that as of now, and I do not plan on spinning mine any higher than 6000 so I think its overkill.
What kind of combo are you running? A stock replacement set might do the job as well.
I got mine from Bret. Paid around $100. Do a search on here for Bret Bauer, you'll find his contact info.
Oh, and with the progear you lose the mechanical water pump, you have to go electric. Kyle |
4 Attachment(s)
I got mine in yesterday from hughes in Washington Il. Their # is (309) 745-9558. I ended up getting part # PG3145T (T is for torrington bearing). It cost me $90.46 shipped ($79.95 before) Here are a few pics.......
Attachment 49370 Attachment 49371 Side view Attachment 49372 Crappy up close pic of gears. Attachment 49373 |
Looks good! I sent an email to Bret, still waiting, and I am going to be running LE2 heads and an CSR ewp.
| All times are GMT -5. The time now is 09:35 AM. |
