timing chain broke AGAIN
Old Dec 6, 2004 | 10:14 AM
  #31
LT4orbust's Avatar
Re: timing chain broke AGAIN
Take a close look at the chain and gears to see if they can tell you anything , are any other links about to break , are the gear teeth wearing evenly? I know with broken parts it may be hard to tell ... but a part that has been running abnormally for awhile will look different then a part that broke suddenly, any chance of the cam walking too much
Old Dec 6, 2004 | 11:46 AM
  #32
96flame's Avatar
Originally Posted by Tom Piper
How about an oil pump where the relief valve is stuck causing extremely high oil pressure and drag on the cam?
Tom Piper
You'd blow the oil filter before anything like that would happen
Old Dec 6, 2004 | 01:52 PM
  #33
GREGG 97Z's Avatar
Originally Posted by RamAir95TA
Is it possible that the crank snout isn't fully seated against the crank gear, causing lateral load on the chain?
That was my 1st thought, I almost did that with my 97 when I installed the Cloyes chain, without the CPS reluctor ring on there the Cloyes crank gear wont seat as far.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
