Timing chain ?
Timing chain ?
Hey guys does any one make a performance timing set for our cars im trying to tfind a gear to gear set rather than the stock gear to chain? also while im doing my timing cover what kind of gains can i look at for putting an electrtic W/P on ?
Rob
Rob
If you switch out to an electric waterpump you will gain around 6-8 rwhp and will be able to run a Cloyes true roller chain. If you decide to stick with your stock waterpump than you can run an LT4 extreme timing set.
