Timing chain
Old Mar 3, 2008 | 04:37 PM
BCdawg57's Avatar
Timing chain
Is there a place i could buy just a replacement chain for my timing gears without having to buy a whole set?
Thanks,
Jake
Old Mar 3, 2008 | 04:40 PM
Any auto parts store or dealer.
The question is why would you want to put a new chain on old, worn gears? The new chain will wear into the worn pattern of the old gears in no time.
Old Mar 3, 2008 | 04:45 PM
Lt1son's Avatar
i have all brand new timing gear, chain and sprockets for LT1 in box brand new from my dealership....$80 plus ship.
Old Mar 3, 2008 | 06:39 PM
crazycat's Avatar
What year is it for ? I need one for a 95... thanks
Old Mar 3, 2008 | 08:24 PM
MeanGreen97Z's Avatar
I picked up a cloyes replacement timing chain from O'Reilly for 12.99$.
Old Mar 3, 2008 | 09:48 PM
greenmachinedriver's Avatar
imo if the gears are in good shape why spend 200 bucks on a set when you can get a cloyes chain as meangreen stated for 13 bucks. i did the same thing.
Old Mar 3, 2008 | 10:03 PM
If there are any kind of miles on them, they are worn. It's that simple.
LT1 chains suffer from enough slack as it is. The chain is only part of the equation.
You could use the rationale that the chains hardly ever break, so why change it at all? But not too many people do that.
Oh, and a stock set is well under $100 (heck, even a Cloyes double roller is).
Obviously, how you treat your car is up to you.
Old Mar 3, 2008 | 10:23 PM
dangalla's Avatar
you should never replace only the chain, thats asking for trouble.
like rob stated the new chain will wear into the old sprockets and the chances of failure are way up
but its all up to you, it is your car. i personally run a factory gm chain and sprockets
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
