timing chain
Old Mar 6, 2007 | 12:17 PM
lt1 beast's Avatar
timing chain
if the timing chaing is placed one tooth off will the engine refuse to start up? or will it run very poorly?
Old Mar 6, 2007 | 12:50 PM
Z95m6's Avatar
I would look and make sure your opti got put on right. If its installed one hole off the car might not start, at least mine wouldn't
Old Mar 6, 2007 | 01:02 PM
blackztpi's Avatar
not necessarily. you would either be advancing or retarding it a link. it will start, but probably run poorly.. worse case senario you can bend pushrods if its off too much
Old Mar 6, 2007 | 02:54 PM
It may idle, but have little or no power. It could depend on which direction it was off.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
