CamaroZ28.Com Message Board
-   -   which timing chain (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/timing-chain-294314/)
LT4orbust Aug 22, 2004 07:47 PM
which timing chain
I'm going with the electric water pump on my 97 lt1, am i going to have to spend over $200 to get a good timing set
n2oCamaro Aug 22, 2004 09:11 PM
Re: which timing chain
Cloyes "True Roller" 9-3145. You may have to clearence the timing cover just a little but for $70-$80 you can't beat it (as long as you are using an elect. water pump.).
LT4orbust Aug 22, 2004 09:15 PM
are they durable enough to use with the 306 cam and ex612 springs, i think i looked this one up before and it didn't specify that it could be used with a 97 lt1
n2oCamaro Aug 22, 2004 09:20 PM
It's a double chain. Plenty strong enough. I am using one on my motor with a slightly larger cam then the 306 and same springs. It will not show up in any parts listing for your car because it cannot be used with the stock water pump.
LT4orbust Aug 22, 2004 09:25 PM
is it a good fit to the opti? i've worked on all types of engines but this one, i know i've asked some odd questions on this site but i'd rather be sure!
LT4orbust Aug 22, 2004 09:32 PM
also what should i set the cam at...0 degree or 4 retard, i will be running a 3200 rpm stall and cc306 with headers.
Spinner Aug 22, 2004 09:48 PM
0 degree
