Tighten Throttle Cable
Old Jun 11, 2003 | 04:54 AM
Twice The Fun's Avatar
Question Tighten Throttle Cable
Pulled my Nitrous off today (had to pull TB off) and now my accelerator pedal has a lot of play in it, i assume i need to tighten the throttle cable....can some one give me detailed instructions on how to tighten up the throttle cable. Also, with it not being fully tightened, I am not getting 100% throttle when i go full throttle, correct??
Old Jun 11, 2003 | 06:52 AM
97FormulaWS-6's Avatar
slack in the pedal is normal....
To check the 100% throttle.. have someone sit in the car with it turned off, and someone else watch the arm on the TB. Have them step on the pedal as far as it goes, as long as the arm is hitting the stop you're at 100% throttle.
If you still require to adjust your cable, it's not possible with a factory cable, you must upgrade to a Lokar unit...
Old Jun 11, 2003 | 09:00 AM
after i remove the nitrous, i noticed more slack in the cable tho...i have heard you can tighten the cable to produce less slack.....??
Old Jun 11, 2003 | 10:16 AM
READ!!!
Old Jun 11, 2003 | 06:56 PM
re-read it, my apoligies.
88IROC_Z
Jul 22, 2015 11:38 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
colts0455
Jul 8, 2015 12:21 AM
