CamaroZ28.Com Message Board
-   -   ticking sound coming from front of car, seems to get faster with higher rpm (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/ticking-sound-coming-front-car-seems-get-faster-higher-rpm-102535/)
sc93 Apr 3, 2003 01:33 PM
I am thinking this may be caused by a small exhaust leak I noticed right before the cat on my 93 Z. Could this be the knock sensor picking up the tick from the exhaust leak?
What else would cause a ticking sound?
treyZ28 Apr 3, 2003 01:44 PM
its probobly the exhuast leak making the noise.
go get some "Tiger Paw" at pep boys
I doubt the KS would pick that up
sc93 Apr 3, 2003 02:29 PM
What is this Tiger Paw you speak of?
treyZ28 Apr 3, 2003 03:01 PM
exhuast wrap i've had good expierence with :)
Zerosheaven Apr 3, 2003 04:10 PM
use a little j-b weld that **** is stong as..... ****
cop01 Apr 3, 2003 07:27 PM
is it connected to rpm or mph?
mineralwater Apr 3, 2003 07:32 PM
I don't think jbweld would hold up to the direct heat of the pipes - i've tried it on my header/ypipe collector, with no luck. The jbweld cracks and peels away after a couple miles.
And depending where the exhaust leak is, the KS *will* pick it up. I had a exhaust leak at the pass. side collector, and it was picking up about 6-8 degrees of kr.
sc93 Apr 3, 2003 08:05 PM
well, both
As the car is moving (I hear it real good in the parking deck at school), and when it is sitting, if I put it in neutral and give it a little gas, it goes faster also.
That's why I feel it is the exhaust leak
93transam1234 Apr 4, 2003 02:46 PM
m
Check ur ignition coil at night in the dark and see if it is sparking. My mark was making that noise
Mr Freeze Apr 4, 2003 02:47 PM
i'm no expert, but i had a ticking sound that was very similar to a lifter tapping...turned out to be a spark plug wire that was arcing to a close ground...pop your hood at night and look where your wires are running...it'll probably be a blue arc if it's a bad wire.
travis
