pre-94 Engine, new cam - Optispark drive
Old 10-12-2003, 12:13 AM
davepl's Avatar
I'm putting together a 396 LT4 based on a '93 engine to go into a '94 car. Before 95, they drove the optispark with a little driveshaft from the center of the cam gear.
95 and later they are driven off of a longer cam pin. The optisparks and timing covers are not interchangeable (more info can be found at http://para.noid.org/~muttvette/opti.html)
Question 1:
This also means the new LT4 and GM Extreme Duty timing sets, which I already blew $250 on, isn't compatible with the 93 optispark... Because it lacks the center "teeth" to turn the 1993 driveshaft. Correct?
Question 2:
So, if I stick with the 1993 timing set and replace the chain, am I at any serious disadvantage?
Question 3:
A late cam is compatible with an early optispark as long as the cam pin is installed at the correct height. How do I change this? Do I saw the pin off at the right height, or can cam pins be removed and replaced, or pounded in further? In other words, how do I get the cam pin on a replacement cam down to the 93 level?
Thanks,
Dave
davepl is offline
Old 10-13-2003, 08:57 AM
Since this relates directly to the LT1/LT4 family of engines, you would probably get better results on "LT1 Tech". Moving it there.
Injuneer is offline
Old 10-15-2003, 02:40 AM
davepl's Avatar
You'd think, but no replies yet :-)
Someone must have run into this before! Help!
davepl is offline
Old 10-15-2003, 07:42 AM
Re: pre-94 Engine, new cam - Optispark drive
Originally posted by davepl
Question 1:
Correct
Question 2:
It would be much better to go with the more robust timing set if you are going to be spinning high rpms on a regular basis. A 95 timing cover is not that expensive and if you are in need of an opti replacement, the vented is cheaper.
Question 3:
Depending on the cam, you may be able to pound it in. If not, grind it down to the proper level.
shoebox is offline
oldschool
02-09-2016 09:21 PM
Injuneer
12-15-2014 09:36 AM
brentbrowning01
12-03-2014 10:36 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
Queens94z28
11-20-2014 06:03 PM
Quick Reply: pre-94 Engine, new cam - Optispark drive
