ticking noise and miss
Hey guys here's my issues I have a ticking sound coming from the driver side valve cover it comes when I'm coming to a stop,it will tick for less than a minute then go away and comes back occasionally.
2nd issue is only when I'm on the freeway when I'm around 65 to 75 mph (3k rpm)and keep my foot on the gas like I wanna go faster the car will hiccup/jerk I seen the rpm like kick back. When I go 0 to 50 no freeway mph the car accelerates perfect and powerful. 1.Car fires up fast and stays on idling perfect. 2. Spark plugs, wires,distributed cap and rotor done,fuel filter,ignition module all been changed,I do what could cause this thank you guys |
Re: ticking noise and miss
What does the oil pressure look like as you are coming to a stop? Does the tick get worse on harder stops?
Originally Posted by Injuneer
(Post 6975245)
Originally Posted by 94Z28LS1toLT1
(Post 6975250)
The oil pressure is below 20 coming to the stop and the ticking is worse on harder stops yes
Just checking to see if it was dropping to "0" which would indicate the oil pump pickup has come loose. Does not appear to be the case. Oil pressure is proportional to RPM.... as RPM drops, pressure drops.
Use a stethoscope to lo locate the specific source of the noise. If it's a valve train component, check the valve adjustment. You second problem, the stumble when to want to accelerate, will probably take a PCM data log to track down. For now, check for a torn rubber inlet elbow, or the elbow not being fully on the throttle body, particularly at the bottom. |
(Post 6975254)
(Post 6975281)
Woo that's good that oil pressure is fine the ticking is coming from the 2 first rocker arms that's closest to throttle.Now how do I adjust the rocker arms without messing them up?and to see if there is play or if they are too loose.Thank you
(Post 6975281)
I don't get any audio on the video, or were you just showing that the rockers are loose?
Use Shoebox's valve adjustment procedure: 4th Gen LT1 F-body Tech Articles |
(Post 6975321)
(Post 6975321)
(Post 6975413)
yes just showing the rockers being loose just found out my lifters are bad on cylinder 1,but do I need to take the intake manifold off and go through the trouble to change the lifters or can I switch oils and motor flush it to get any sludge I think this didn't happen till I used Castrol edge10 30 fully senthentic
Just changed oil to 5w 30 valvoline now ticking is gone......so is valvoline better then Castrol edge fully synthetic 1030.hella confused about the ticking problem I had.
Lifter is bad in cyl 1
| All times are GMT -5. The time now is 01:06 AM. |
