CamaroZ28.Com Message Board
-   -   throwing service engine light.....need help! (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/throwing-service-engine-light-need-help-694644/)
Tanner_94_Z28 Jun 20, 2009 03:12 PM
at low rpms or normal driving my car runs smooth and sounds good but when giving it a hard acceleration it seems to miss and throw service engine light doesn't want to shift i cn't figure it out anyone have any ideas?
moparman Jun 20, 2009 03:52 PM
You need to find someone with a code reader or scan tool that can pull the codes.
Tanner_94_Z28 Jun 25, 2009 05:34 PM
well i took it to autozone and they said that they don't have a code reader for that model and took a paper clip the port under the dash and said that it should flash a code through my service engine light and it didn't flash a code or anything do they make code readers for these models
94CamaroZ28/SSClone Jun 25, 2009 06:13 PM
Autozone never has a OBD1 Scanner, they have it for OBD2. Your 1994 Camaro is OBD1, Those guys don't know what there talking about. Go to Pep Boys, Im sure they will have a OBD1 Scanner, if they don't do it for free. I'm sure they can at least sell you one.
moparman Jun 25, 2009 06:16 PM
Yes, you can get an OBDI code reader or scan tool. The paper clip trick doesn't work on '94 and up.
I think Pep Boys charges you to read the codes.
