CamaroZ28.Com Message Board
-   -   Throttle Position Sensor? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/throttle-position-sensor-353362/)
Black6spdZ Mar 28, 2005 01:24 PM
I replaced mine today because it threw a code. The code is gone but now the car idles at like 1400 and doesnt drop down, is there any adjustments or anything i can do to calibrate it?
shoebox Mar 28, 2005 02:04 PM
Re: Throttle Position Sensor?
It normally should not need any adjustment (there actually is none). You can check the voltage and throttle opening percentage with a scanner to make sure it is working correctly.
Black6spdZ Mar 28, 2005 02:10 PM
thats what i thought, i fixed it with the adjustment screw my throttle plates were sticking
