Throttle linkage sticking
I just installed a 52mm BBK TB. My linkage did not stick before but now seems to stop just before the idle screw and keeps the car revved up until I give it another quick shot of gas. I put some grease on the throttle spring but still no luck. Anything else to try?
I called BBK today and no help from them. Someone mentioned it may be the blades touching? Any help would be appreciated.
Originally Posted by rsjay
(Post 4545505)
What LiENUS mentioned appears to be a common issue with BBK throttle bodies. I've read a few complaints about it before and checked my own BBK throttle body (purchased used) and found it was already welded.
